- SnomasExplorerDecor sealant or eternabond. I use both. eternabond is an excellent product that adheres well if installed properly. Check their website for installation video. Then you can choose the best way for you.
- msmith1199Explorer IIThis is a thread on how I re-did my front seam: Enternabond Tape on the front seam
jplante4 wrote:
Both. Clean the seam of old caulk, seal the seam with Eternabond, feather the edges and seal with Dicor.
This is what I did with a couple of exceptions. I completely took the seam apart and removed the old screws. I think put new screws and used some pieces of oak inside on the back of the roof to give the screws something to eat in to. I couldn't get to the entire seam from the bottom, but I got to about four feet of the center. Then before putting the Eternabond tape on. I sealed the seam with Dicor, being careful not to over do it. The ertnabond won't stick to the Dicor so I made sure just to seal under the seam and leave the fiberglass explosed. Been working for two years now with no leaks. I posted photos on here, I'll try and find them and post the links. - jplante4Explorer IIBoth. Clean the seam of old caulk, seal the seam with Eternabond, feather the edges and seal with Dicor.
- olfarmerExplorer II
10forty2 wrote:
Dicor Lap Sealant. Self leveling for flat surfaces and Non-Sag for the vertical surfaces.
I second Dicor Lap Sealant. I have had very good luck with it. :) - 10forty2ExplorerDicor Lap Sealant. Self leveling for flat surfaces and Non-Sag for the vertical surfaces.
- gboppExplorerUse Eternabond tape if possible. It will last much longer than caulk.
38,782 PostsLatest Activity: Sep 10, 2026
