Sam_Spade
Nov 26, 2015Explorer
Kayteg1 wrote:
If you leave them for less than 6 month, I usually just disconnect the clamp.
For longer storage battery MAINTAINER with floating circuit is the only thing that will keep the batteries healthy.
Battery maintainers don't require removing the caps, but they fail occasionally too, so checking them once a month is advised.
This.......IF they are AGM's.
But yours with caps shouldn't sit that long; 2 months max.
A small automatic tender type charges is probably your best option.
I start mine every 30 days or so and run the engine long enough to get HOT (about 20 minutes). This also tops up the batteries.
