j-d
Jul 03, 2017Explorer II
CapriRacer wrote:
The minimum dual spacing for an 8.00R16.5 is 9.0" and for an 8.75R16.5, 9.9". That means that the gap between freestanding duals is 1" and 1.15" respectively.
Now I'm going to guess that Cheryl has 6" wide rims, and that means we get 0.3" more to play with.
I'm trying my best. I had errands this morning, so I took my "offset gauges" (a piece of 2x4 and a couple thinner boards, thinking I'd stop at a Chevy based Class C I'd seen sitting for sale in a strip mall parking lot. Reach under and check. Coach was gone.
Then I went to a tire store and asked for the Offset Specs on 8.00 and 8.75 tires. All they could offer was to bring in a couple 8.75's, dismount a pair of 8.00's, mount 8.75's and see what the spacing was. They knew about offset/sidewall clearance, but could not find the specs in their sources, including a call to the tire distributor.
Tires in question were Firestone Transforce, so I pulled up firestonetires.com, and requested "Chat with an Agent" but no reply. I doubt I'll get through before the holiday (maybe the holiday week) is over.
Time to figure out Cheryl's actual Rim Spacing, so:
CHERYL: Front and Center!
In this diagram, posted above, copied here to make it easier for you,
The two top surfaces represent the tread surfaces of a pair of dual tires.
The two words at the bottom are "Dual Spacing" and they're showing it being measured from a point in each rim, that you can't see unless the tires are off the rims.
BUT! You can take your trusty 12" ruler, and measure from any point on the tread of one tire to the same point on the tread of the other. Say a groove runs right down the center of the tread of your tires. Measure the distance from that groove of the inner tire to the same groove on the outer tire.
THAT is your Dual Spacing Specification!!! With that, we can look at Barry's spec of 9.9" and see if you're safe. 9-7/8" is about 9.9" so you're good. More doesn't hurt. I'd go 9-3/4" but much less is a concern. That's just me, and I've been around a lot but I'm NOT a Tire Man and CapriRacer is.
Shouldn't be this difficult, but remember, the kid at the tire store, even the assistant manager, was in K4 when Chevy quit 16.5" tires.
38,778 PostsLatest Activity: Jun 10, 2026
