j-d
Jul 03, 2017Explorer II
CapriRacer wrote:
And if I am right that Cheryl has 6" rims, the spacing could be as low as 9 1/2" and still be good - and based on my experience, there is some additional clearance to make sure things work out, so I'm guessing if the spacing is 9 1/4" or greater, Cheryl should be good to go!
So Cheryl, measure carefully. Find the same spot on each of the tires, and hopefully the tires are the same brand and type.
Take another look at that label where you found 16.5 and see if the Rim Width is there. I just looked at ours (2002 Ford with 16" wheels) and the label says "16x6" which is Diameter x Width, and we're looking for 6"...
38,778 PostsLatest Activity: Jun 10, 2026
