CapriRacer
Jul 04, 2017Explorer II
Cheryl_B wrote:
Just a smidge under 10". I did the best I could but the two tires don't line up exactly and there are 5 sections of swerving treads and I had to pick a spot and do my best.
Contrary to what I thought, looks like the manufacturer used the wider dual spacing. That's good fortunate for Cheryl. That means that there is at least ah .... let's say well known tire manufacturer where you can get tires.
But I'm going to bet these will have to be ordered no matter where you go.
And those 5 sections of "swerving tread" are likely the outline of a pattern we tire engineers call "pitch sequence", where the tread pattern varies slightly in size so as to not set up a vibration around the tire.
And a words to the wise for anyone who has 16.5" tires. I expect the availability of these tires to get worse and worse until the only place you will be able to get them is from a vintage tire outlet like Coker tire. My advice would be to change over to 16" - and do the planning and initial work (buying wheels) while you have the time. It will take a while to get it straight!
38,778 PostsLatest Activity: Jun 10, 2026
