- eric1514Explorer
- atreisExplorerRoad: I use a TomTom. From everything I've heard, Garmin are good too.
Hiking (US): I use my phone and BackCountry Navigator Pro. (The phone is a Sony, running Android, Ice Cream Sandwich, and has built-in GPS. It can also triangulate between towers if there are towers within receiving distance, which can sometimes help in dense forests or other places where GPS signals are week but which have cell coverage. For power, I use a solar charger, and an extra battery pack. It works well enough for 3-4 day backpacking trips, and I didn't have to buy another (expensive) device.)
Hiking (Canada): Haven't found a good solution aside from a compass and paper maps or print-outs (from TopoRama) done before setting out. (The Canada maps available for BackCountry Navigator require a data connection, which is a non-starter. A handheld Garmin would work here, but costs...) - DakzukiExplorer IIWe use a Garmin GPS in conjunction with an iPhone (google maps) and Gazetteer for planning. For hiking a hand held and compass is the deal.
The iPhone is good for planning fuel stops using Gasbuddy and Google maps for ingress egress when towing. - nadsabExplorer
pnichols wrote:
nadsab,
By the way ... you have an excellent RV for the type of camping you prefer!
We use a late model high end five inch Garmin vehicle navigator on the dash of our RV. I say "late model high end" because they do make continual improvements in their line and lower models in their line do have irritating usability negatives because of technology differences. We have had earlier, lesser, models and our latest one really is a breath of fresh air to use. We keep it updated continually and it's solid state memory can hold all of North America plus hundreds of thousands of custom POI's on tap. The particular model we have can now be bought for way less than we paid for it last fall.
That being said, we also use several (an entire book is required for each state) outstanding map books along with the Garmin. These map books show extreme detail, especially outside cities in the countryside for each state - including obscure camp grounds and points of interest. We rockhound a lot in remote places beyond campgrounds - we often camp way out there too - so we use all three on concert ... the Garmin, the map books, and ultra-detailed specialized rockhound map guides.
Other posters above have mentioned that most vehicle navigators probably won't work for pedestrian use due to battery life ... which is true for most models. However, our Garmin vehicle navigator does have a superb instant-on/instant-off sleep feature that extends it's battery life to many days ... supposedly so you can merely switch it on to check you position then switch it back off to proceed when walking/hiking. We haven't used it this way yet, though.
Here's a link to those great map books - like anything worth it's salt they're not inexpensive:
http://www.benchmarkmaps.com/
Thanks that's why we bought the Four winds, it can get into some really tight spaces.
By POI - I assume you mean Point of Interest?
For your map books have you ever used the Delorme atlases?
Which model number of the Garmin do you use? - WyoTravelerExplorerWe have a new Garmin GPS. Don't use it. We use maps on smart phone. Better GPS.
- kirklandscExplorerI just have a cheap Garmin Nuvi. A gps is a tool that should be used along with common sense and research. I always try to research my entire route online on Google maps before I go. I will use street view in any tricky sections and make notes of mileage and where I need turn. I have saved a lot of missed turns and u-turns by doing so.
- pnicholsExplorer IInadsab,
http://www.benchmarkmaps.com/ - HarvardExplorer
Coalminer UG wrote:
I prefer a good up to date map to compliment any GPS system.
I have seen to many times where people have used just GPS and got them selves in deep trouble.
albert-chretien-body-found
"Sheriff's Deputy David Prall told The Associated Press that the battery on the GPS — which steered the couple in the wrong direction in the first place — probably burnt out and his path began to angle too far north." - Coalminer_UGExplorerI prefer a good up to date map to compliment any GPS system.
I have seen to many times where people have used just GPS and got them selves in deep trouble. - nadsabExplorerOK if I use our laptop, what would be a good GPS card for use with Street Alas, Strips & Treets or Coopilot? We have a USB 3 port and an SD port on laptop...
38,758 PostsLatest Activity: Nov 04, 2025
