Need a little advice.. Leaving central California, heading to Dickinson, Nd. Trying to avoid climbing months if possible. Are the climbs through, SLC, and Wyoming Ok? Or should I add several hrs...
Thanks for the replies. I also found this ... http://www.violette.com/Story-N.aspx?rcd=999...which pretty much sums it up and if it's no worse than Donner, then we'll probably be OK without having to disconnect the toad. Think I'll just hang it down in low gear with the four ways on and take real easy this time.
