Romer1 wrote:
What was involved in adding that riser? Do you need to extend the piping? Does it just fit existing mounting or do you have to make any changes?
The riser fits down on the existing mount (with its own seal) and bolt set, then the toilet sits on top of the riser (with its own seal & bolts)....very easy.
Ive had it in place for a little more than a year and probably 10k miles or more with out any issues.
it requires ZERO modification to the floor or plumbing - so if you don't like it or change your mind, it can easily be removed & returned to "stock".
