rr2254545 wrote:
To download to Garmin it is easy - first using the trip tool - click send to GPS -click on download csv file - this will place the file on your computer
Then using the Garmin "POI loader" install the file to your Garmin you can get the loader from the Garmin website
Actually this is not true. To upload to Garmin RV785, you must use Garmin basecamp. RV trip wizard creates a GPX file. Garmin rv 785 does not accept cvs files. The GPX file is imported into basecamp which loads it into the the GPS. The problem is it is POI's sorted alphabetically. It is not imported as a multi stop trip. As I said, use the RV trip wizard for planning and just key in the address each morning before departure.
Ken
