IAMICHABOD
Jan 13, 2021Explorer III
It looks like you did settle for the best solution,that is extending the valve stems.
Might I suggest that maybe the next time you get tires or decide to make a permanent fix to install extended valve stems.
The ones you need are from Borg AKA Your Tire Supply. Dually Kit
They will look like this. The valve stems for Duallys. I have a set from another vendor that was the original maker of them and have been on my Class C for over 10 years with no leaks or problems. You can Check the pressure on all tires in a matter of minutes.
Valve stems
Valve stems
38,782 PostsLatest Activity: Sep 10, 2026
