TxGearhead
Jan 19, 2021Explorer II
My 2018 Ram with alloy wheels has little 2 inch plastic extensions on the inner tires that have a little white button that has to be depressed to air up or down. I don't trust them. I tried cheap chinese valve extensions and good Milton extensions. Neither would work consistently. They both had to be screwed on to the tire valve in an exact spot to be able to press against the inner valve stem on the tire. I tried screwing the tire valve in and out and never could hit the sweet spot. I have reverted to the plastic OEM extensions. I did get some extras from my dealer.
I air up and down a lot. I air up to hitch the 5th and air back down as soon as the 5th is off and in storage.
I have heard that the equalizer system has a problem in that if one tire leaks down the other one will too. True?
38,782 PostsLatest Activity: Sep 10, 2026
