MountainAir05
Apr 06, 2019Explorer II
Here is what I did, I filled the holding tanks full and the fresh water full and the gas full. Just the two of us. I then weight the vehicle and got my load per axle. That is the max weight that you will never have unless you travel with everything full. Dump the black/grey and put the fresh water at where you travel at. We stay around just a little over a 1/4. Then set the tire pressure and that is where I ran them. My tires are 19.5/245. I ran then for 10 years and never a issue. Handling and ride was good. Even wear. 78000 miles on them. I do not add pounds as many other state.
As you said, hard to weight every time you travel.
