naturist
Apr 07, 2019Nomad II
The simple truth is that the optimal tire pressure is a function of the weight that tire is carrying, and there is no magical one-size-fits-all pressure. If you put in enough air to safely carry a heavy load, then run light, you will get a hard and squirrelly ride, as you experienced. If you fill to optimal for a light load, then pile on lots of weight, you’ll get a wallowing and squirrelly ride. It’s directionally unstable both ways, just for different reasons.
Although you can’t weigh every time you start the engine, you can adjust the pressure to light or heavy pressures based on an estimate.
