lanerd
Aug 27, 2014Explorer II
valhalla360 wrote:lanerd wrote:I'm pretty sure your battery minder needs 120vac even if it's hard wired.
Of course it does. :h
From your last post:
"The Trik-l-start needs no 120v and once installed, no..."
This is about the 3rd time you say the hard wired unit doesn't need 120vac but now you say of course it needs needs 120vac.:h
No...go back and read what you posted! You said the "I'm pretty sure your battery minder needs 120vac even if it's hard wired. ... I agreed with that statement....of course it does.
What I said was the Trik-l-start does not need 120v.
And you are dead wrong if you substitute Trik-l-start for Battery Minder in that statement. As others have mentioned also....Trik-l-start does NOT require 120v...period!
Ron
38,769 PostsLatest Activity: Apr 03, 2026
