DutchmenSport
May 11, 2016Explorer
Doesn't matter if it's a million dollar motor home or a $100 used pop-up, the principle is the same. Use a carpenter's square and put blocks under the wheels.
I have found the best place to find "level" is on the door frame with a carpenter's level. Hold it vertical against the frame, and use the horizontal bubble. Turn it 90 degrees and the other direction.
Of course with a motor home, you don't have the advantage of cranking the tongue up or down. But still, tires on board or blocks, or Lynx blocks... it's the only way.
38,780 PostsLatest Activity: Nov 22, 2015
