- RacormanExplorerThanks guys..........
- BozemanTrailExplorer
DSDP Don wrote:
With regards to the cables, I like to use the small plastic cable hold downs and then completely cover each hold down and section of cable it's securing with a dollop of Dicor.
I use the same trick for cables. - DSDP_DonExplorerAnytime I install something where I can't or don't want to use a really stout bracket, I use 2 sided foam tape under the bracket, then screw it down and then use Dicor to cover and seal the bracket.
With regards to the cables, I like to use the small plastic cable hold downs and then completely cover each hold down and section of cable it's securing with a dollop of Dicor. - Executive45Explorer IIIFor the wires, use a dollop of Dicor Self Leveling Lap Sealant...Dennis
- pianotunaNomad IIIFor the brackets VHB tape from 3M. Dicor for the wires.
- BumpyroadExplorer3M 4200 or 5200
bumpy - donn0128Explorer IIDicor Lap Seal. My wiring has been held in place with dabs of Dicor for nearly 10 years. A couple of times I have cleaned the old and added a bit of new, but not often.
38,778 PostsLatest Activity: Jun 06, 2026
