Grandpere's avatar
Grandpere
Bi Polar Vacation
We had a wondrous time on our vacation despite a total of 4 breakdowns. The first I shared already and it was the only one going out to Montana. Coming home was another matter, let me back up to our arrival. When we got to my dad's place and parked, the next day I had a large puddle of transmission fluid under the mh, turns out one of the transmission lines ruptured. So I added a quart of tranny fluid and headed over to the mechanic. He replaced both tranny hoses and added a cooler because what I though was the tranny cooler turned out to be for the roof AC. 3 quarts of fluid, new lines, and a new cooler and that problem was solved--2 day delay. On the way home, the serpentine belt broke and tore up one of my new tranny hoses, so a new belt another hose plus another 2 day delay and we are moving again. The third breakdown on the way home was a combination of things, my sewer hose holder broke and it was flailing around going down the highway and we were flagged down by a fellow RVer. So I stopped along side the freeway and got the hose stowed into one of the basement compartments. Then the "fun" began, I tried to start the mh and nothing happened, no click, no grunt, just a very loud silence. So I called Good Sam again and 3 hours later a wrecker shows up to take us into Omaha, NB--we are like 20 miles away from it. The new starter, put on before trip started as old one was not functioning properly, had cooked itself. So 1.5 days later with a new starter installed we made it the rest of the way home with no incident.
Then there was the problems that cropped up while we were in Montana, the Suburban furnace decides it will not function anymore, and the hot water heater tries to catch fire and melts all the wiring on the control panel. And to add the icing to the cake, the water pump for the fresh water tank decides it has had enough and also stops working.
So as far as maiden voyages goes, it was the best of times and it was the worst of times--apologies to Charles Dickens.
  • Bill.Satellite wrote:
    Could you explain this part? I have never seen a roof air that had an external cooling system much less one that would be anywhere near where a transmission cooler would be located.
    Thanks.
    I wish I could upload a picture of the set up, I am just telling everyone what an rv mechanic told me it was, and the chassis mechanic that put in the tranny cooler agreed. It seemed strange to me so in my ignorance I can only share what I was told.
    Thanks.
  • Peralko wrote:
    Sounds like a good plot for the next Chevy Chase Vacation movie!
    Yah, if he has a son by the same name! :)
  • Your post sounds familiar to another one. The poster had about as much extracurricular activities as you, only his was stretched over his trip.
    Isn't this a wonderful life? LOL
  • Sounds like a good plot for the next Chevy Chase Vacation movie! Glad you got through it, and hope this will be it for your motorhome worries for a while.
  • On a positive note, you have many new components now that you won't have to worry about for a while.
  • Thanks for that. It makes every trip we have made over the last 30 years (except one) look good in comparison.
