Have a 96 HR Endeavor DP. Freightliner chassis, 230 Cummins w Allison 6 speed. Need to know where the fuse is for the vacuum pump that runs the a.c. dash duct work. Also the source of the 12 v power. ...
I am not sure what your MH used, but I used to have a Fleetwood Southwind with a 230 Cummings, it used a 12 v vacuum pump that was the same as used in the medical field, I had to replace mine, and it turned out to be the same one that was mounted on portable computer stands that the Nurses use in the Hospital to provide vacuum to a patients when they move them around the hospital., And yes it is a continuous duty pump.
