Bayoublue's avatar
Bayoublue
Black Tank Flush
Hello Everybody
I'm interested in a Winnebago via 25T. I saw one locally and I did not see a 'Black Tank Flush' hose connection anywhere on the unit. Can you tell me if it has one and it's location?
Thank You
  • i just installed TWO tornado's this week....beats the hell putta hauling a hose inside & risking a wet interior !
    In my particular install i could not get high enough at the back of the tank, so i installed them in the side - I've never had an issue with tank odors (but then i throughly rinsed my black tanks by sticking a hose down the toilet).
    I added some quick disconnects & have a short bit of hose that i connect to the water/rinse source....which makes it easier to connect the hose to the tanks.
    the QD fittings make it easier to put the "cap" back on too.
    my only regret is that i should have done this years ago - but was too apprehensive about putting a hole in my tanks.
  • Thanks, I'm new to RVing but I'm assuming that a 'Tornado Flusher' is the sprayer fitting that would be mounted to the wall of the tank? Then you would connect your hose to it?
  • Not sure about the T, I suspect it does not come with one. My P did not come with one but it was extremely easy to add. The non-opening door in front of the water bay is still on a hinge and can be opened by removing 4 screws. Then I was looking at the side of the black tank and added a Tornado flusher there. Good luck!
