musicmole's avatar
musicmole
Black Tank Problem
I have a situation that baffles me. A year ago i replaced the water pump in my unit. Since then, if i forget to turn the water pump off while running down the road, somehow my fresh water winds up filling up my bathroom sink then overflows into my black tank which then overflows creating a disaster. If the pump is turned off, no problem what so ever. The pump seems to work normally.
I've had a friend of mine that works on RV's professionally check it out and it left him scratching his head.
I wondering if anybody has any input on this.
Thanks
  • Water pumps dont run unless there is an opening. You either have a leak, a faucet dripping or a check valve that has failed. There is a built in pressure switch in the pump that senses low pressure and turns the pump on. From there water flows to the source of the opening. It aint rocket science and should be easy to diagnose
