bmwbobExplorerMar 02, 2015Black water gate valve replacementOur '99 DSDP has a Valterra 3" Bladex gate valve in the black water line which appears to be leaking (down the tube, not out of the valve body). It LOOKS like I should be able to simply remove the fo...Show More
stew47ExplorerMar 02, 2015Bolts will likely break. At least mine did when I replaced. Kit came with new boots and nuts though.
Related ContentWater pump?Water Heater Replacement RecommendationsWhy no hot water?black water tank replacementBlack Water Accident
