bmwbobExplorerMar 02, 2015Black water gate valve replacementOur '99 DSDP has a Valterra 3" Bladex gate valve in the black water line which appears to be leaking (down the tube, not out of the valve body). It LOOKS like I should be able to simply remove the fo...Show More
midnightsadieExplorer IIMar 02, 2015put stainless bolts back in, easy to change three years from now. and lube things up with water proof grease.
Related ContentWater pump?Water Heater Replacement RecommendationsWhy no hot water?black water tank replacementBlack Water Accident
