bmwbobExplorerMar 02, 2015Black water gate valve replacementOur '99 DSDP has a Valterra 3" Bladex gate valve in the black water line which appears to be leaking (down the tube, not out of the valve body). It LOOKS like I should be able to simply remove the fo...Show More
uncle_tExplorerMar 03, 2015been there done that. easy job. maybe overkill but I used jacks to tilt coach away from the drain. tell anyone in coach what not to do.
Related ContentWater pump?Water Heater Replacement RecommendationsWhy no hot water?black water tank replacementBlack Water Accident
