bmwbob's avatar
bmwbob
Black water gate valve replacement
Our '99 DSDP has a Valterra 3" Bladex gate valve in the black water line which appears to be leaking (down the tube, not out of the valve body).
It LOOKS like I should be able to simply remove the four stainless nuts and bolts that mount the valve in the drain, and pull the defective valve straight out, simply reversing the procedure to install the new one.
Is that about it, or is there more to this job than meets the eye?
Bob
  • That's about it.
    I replaced one of mine one time. Remove 4 bolts and just slide the new one in.
    Easy cheesy!
  • Only problem some have is keeping the seals in place while sliding the valve into place. Using something like rigid plastic as a retainer while sliding the unit works. Sides of a gallon milk jug works. Use the plastic as the bread to sandwich the valve on both sides.
