I got a Giggle out of that! So sorry. Just drain the tanks once a day, only until no moisture comes out. If they feel mushy, take a (/16 wrench and a balpeen hammer and get under there and adjust them. There are 691,000 articles on the net on how to adjust. I go down til they are tight and backoff 1/2 turn. You use the balpeen to tap the lock nut down by tapping on the wrench while holding it over the adjusting jut. It will slide downward and when you get done should slide back up (It's spring loaded) and lock the adjusting screw.
Any Questions?
The boss is always right.
Payday is every other Friday.
Crap rolls downhill.
Don't chew your fingernails.
Any Questions?
