Bikeboy57's avatar
Bikeboy57
Blew inside dual, destroyed airbag and HCV
I blew an inside drive tire on the passenger side. The flailing tire took out the forward airbag and destroyed the Height Control Valve.
Getting a roadside tire fix was as straightforward as it normally is. But with the airbag gone and the HCV wrecked there were two other problems that needed a hack before we could leave the emergency lane.
Lucky for me I had a handsaw on board, so I cut two pieces of the 4x4 cribbing I carry, to put between the frame and the suspension to replace the airbag. I suggest you look at your coach and cut appropriate blocks to fit your coach. Cut the pieces so the end grain carries the load. I had pressure treated lumber but I think oak would be stronger.
Next, I removed the air supply to the HCV and capped it, since the destroyed HCV prevented the coach from building air pressure. Of course this was easier with the tires removed !!!
The point of this post is to hopefully help a brother in the future if you have this incident. So, cut these two pieces of wood before your next trip and put them in the coach. Second make sure you have the fittings to cap and seal both 1/4 and 3/8 tubing. That's a handy hack for many airline problems.
Next, David's Commercial Tire in Knoxville deserves kudos for the initial rescue, crediting me for the temporary tire when I chose to install two new Michelins, and helping me get warranty coverage for the failed tire. These were really nice folks, and epitomized customer service.
I chose to replace the outside dual for two reasons, the first being I did not know if the inside leaked pressure which would have overloaded the outside for some miles, and the tires would have been different diameters putting more load on the inside tire which already carries more load due to the crown in the road. I didn't want to wonder about potential tire damage whilst driving in hot weather.
Any discussion about the tire failure is speculation and unprovable. I am happy with Michelin's response and warranty. This is not intended as a thread about tire failure issues.
  • I'm not a motorhome person...responding just to commend OP for being prepared (he musta been a Boy Scout), understanding his vehicle's systems, and using a little ingenuity.....I, myself, have a 28 year old stepson who, until I recently showed him, had no idea of how to change a tire...
    Many in OP's position likely would have been stuck alongside the road until being unceremoniously towed away by a gargantuan wrecker (with, presumably, a gargantuan tow bill).
  • yes I thought it would also
    I see all the time people trying to fix or complaining at the 1000s of dollars spent on a tire blowout damage when insurance should cover the repair.. Thats why I HAVE insurance :-)
  • If you have comprehensive on the MH it should cover the damage. I had a blowout on my F350 3 weeks ago and it mangled the fender and exhaust pipe. Almost $5,000 damage. Insurance covering all but the $100 deductible.
  • Doesn"t your vehicle comprehensive insurance cover the cost of this damage repaired at a shop ( not the tire)?? Minus deductable of course ..?
  • I had the same thing happen 4 wks ago. I am considering replacing airbag myself and valve also. Anyone had experience DIY? Great idea on having blocks to fill space. Have you repaired yet and if so was cost high? Thanks.
