UssaultExplorerJan 15, 2018Block heater locationI have just bought a 2004 Tiffin Phaeton. Live in White House, TN. I need to find the location for the block heater receptacle. Where do I look?
7 RepliesReplies sorted by NewestBill1374ExplorerJan 16, 2018Mine has the switch at the foot of the bed. The outlet is under the bed towards the rear of the coach. On mine, the lead is tagged for block heater.Only downer is that with the switch mounted low, my large lab sleeping at the foot of the bed will occasionally turn it on.Bill_SatelliteExplorer IIJan 16, 2018http://www.tiffinrvnetwork.com/forum/viewforum.php?f=111Best Tiffin info anywhere!Blaster_ManExplorerJan 16, 2018The plug on my last two coaches was in the bay with the power cord. It was activated by a switch in the back of the coach near the closet.sailor_louExplorerJan 16, 2018Telling you where it is on my rig will provide little to no help. If another Tiffin owner with the same rig doesn't jump in soon, try posting your question on the iRV2 Tiffin Owners Group. Good luck.Tiffin OwnersLou05 Travel Supreme Envoyro_sieExplorerJan 16, 2018Our Fleetwood has one on the bed frame under the end of the mattress.eHoeflerExplorer IIJan 16, 2018Check under the bed inside the bed for a switch, looks like a regular light switch.accsysExplorerJan 16, 2018Not sure about yours but on mine it is in the electric bay and there is an engine heat switch on the driver's left console.
Related ContentFuse panel locateblock heaterFCFS Site locationsTurnbuckle blocks gas capBe careful with engine block heaters
