Remanufactured typically comes with a full "Like new" warranty.
And what is more a set of skilled technicians have gone over it with a fine toothed micrometer and made sure the engine is spec... The odds of a Re-man failing are actually LOWER than brand new.
Seals and other things that wear are replaced... Bacsically a Reman engine has an original block, an original crank MAY have original pistions and head, but the rings are replaced, Connecting rods may or may not be original, bearings are new. The things that wear out are replaced or re-surfaced. (Cylinder walls) you might pick up a cubic inch of displacement if that is done. (or less).
