- cwitExplorerI would want them to show me just where it is leaking. All they have to do is put pressure on the system.
- TheHobeExplorerYou might try a head gasket sealing product as a first/last resort. I do no personally know if these work but it is certainly worth a try before spending probably $3-5,000 on a head replacement. You should indicate what preceeded the problem so we can get a better idea of what may have happened.
- ferndaleflyerExplorer IIIReplaced engine once already and new one has 3000mi on it something is wrong here---those motors last a lot longer than that. And if only 3000mi isn't it under warranty?
- rgatijnet1Explorer III
kcgaz wrote:
Thanks for all of the input, the rig has 22K miles and the engine was replaced and only has 3K miles on it.
Was the engine replaced because of a faulty MAS sensor?
If it was not diagnosed and changed along with this new engine, this could be the reason for your problems with this replacement engine after only 3,000 miles. If the sensor is not detecting any pinging from the engine it will allow the engine to self destruct. - Dennis37ExplorerBe sure it is the head. I though I had a bad head gasket. Turned out to be a loose clamp on the heater hose that is close to the thermostat housing.
- kcgazExplorerThanks for all of the input.
- vjstangeloExplorerIf it were me, I'd just change the head gasket and move on. The 8.1 is a durable engine and will likely give many more years of service.
- kenbertExplorerhttps://www.amazon.com/BlueDevil-Head-Gasket-Sealer-ounce/dp/B000NOO798
Check this out, follow directions exactly and it will work. - 1320FastbackExplorerHow many miles are on the engine?
Has the motor ever overheated?
Have oil changes always been done on schedule?
I'd say if less than 70,000 miles without ever overheating and regular oil changes the bottom end is probably in great shape and just changing the head gaskets would give many more years of service. - BurbManExplorer IIIJasper in a MH makes a lot of sense because of their nationwide warranty
38,782 PostsLatest Activity: Sep 10, 2026
