traveylin's avatar
traveylin
Blowout at 70 mph
We experienced a drivers side front wheel blow out at 70 mph Wednesday going north on US 59 towards Houston after passing a vehicle. The tire blew out about a baseball sized section of sidewall with a report like a gun shot. Some thoughts below.
The tire was a Goodyear 19.5 inch motor home tire that was 5 years old and 35000 miles, rubber looked good. Pressure had been checked the day before by my tire dealer. I had planned to replace all 6 this winter. I had roadside service replace both front tires with there available Michelin.
Most important, I had both hands on the steering wheel and controlling the mh was not that difficult. Normally I pull a toad, and the wheel looked like it rode on the side wall okey for the coast down.
Immediate response was to take foot off accelerator, and check mirrors for other vehicles. I moved to the center of the two north bound lanes slowing down to 35, then exiting right to access lane. Only when I got to 15 or less did wheel wobble start. We traveled about 2000 feet from start to finish and considered ourselves very lucky.
We did the Good Sam call and are pleased with the response. They located a Strouhall tire shop not far away, verified they had the tires and gave us a firm quoted price, did a credit card purchase through Good Sam to release Strouhall to do the work. Most difficult part was coordinating direction, GS person has a different data base than our GPS and street naming/county road numbers came cause uncertainty. Immediately following the work, Good Sam gave us a follow-up call to verify that the work had been done to our satisfaction.
Road side changing of tire rims is a throw back to the days of using tire irons alone. Because of the blown tire, the young man asked that I use the onboard hydraulic jacks to lift the axle enough to get his portable in place. I lifted the front end high enough to change the tires and he simply slid the jack in position. He claimed I saved him an hour of south Texas noon day work with that assistance. Do to roadside installation wheels were not balanced. No vibration or pulling was noticed at highway speeds, but I will have them balanced when the back four are replaced this winter. I tipped the dude 40 bucks for the good experience.
Could have been much worse!! I am out about 300 dollars because I would not shop the cost of replacement on the side of the highway and I was gonna replace them anyway.
peace
  • So glad you're okay and that there was service available to get you back on the road so quickly.
    You're right: It could have been so much worse.
    Good job keeping a clear head during the emergency, too!
  • Videos be damned! While the OP didn't follow the "advice" given in the video, he managed to control and safely pull his coach off the roadway with no injuries. I'd call that a WIN !
    That said, there's NO GOODYEAR 19.5 size tire rated for 70MPH. Please drive safely...Dennis
  • You messed up directly from the Michelin website all - should view the video
    RV tire rapid air loss–most commonly referred to as a "tire blowout"–can be managed. This video teaches you simple techniques to maintain control of your vehicle should you experience rapid air loss on the road. For example, immediate braking: not helpful. Stepping onto the accelerator: helpful.
    Link to video
    http://www.michelinrvtires.com/tires/tires-101/tire-maintenance-and-safety/how-to-handle-a-blowout/
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    First: Thare some videos around here in a STICKY at the top of one of the forums which say Watching these videos MAY (emphasis mine) Save your life.
    Believe the subject, there is only one video.
    Second. You said you had the dealer check the pressure.. Have you ever scaled the RV? Two pressures all but guaranteed to be wrong for your RV are
    The one on the sticker inside the RV
    The Maximum Pressure (Used only if carrying maximum load) Both of which are molded into the tire itself.
    Oh and a 3rd one.. The one the dealer inflates it too.
    Only way to get it right is to scale it and look up the proper pressure.
    Someday they'll know the gps coordinates of your phone..maybe. By then a voice call won't be necessary.
  • CA Traveler wrote:
    Wow good job! Never heard of the Goodyear tire company. :h But I'm familiar with BadYear tires. :)
    A rather inane comment. I've used Goodyear tires for over 40 years, on various sized vehicles, and never had a bad experience with any of them. Some folks just get lucky, I guess.
  • Wow good job! Never heard of the Goodyear tire company. :h But I'm familiar with BadYear tires. :)
