RichNewcome wrote:
I guess my point was that it doesn't really matter if it's doesn't keep its position as long as it goes back, presses against the seat, and has enough stroke to push the pedal. Mine acted in a similar fashion.
Mine does all that, but the seat cushion is too thick I think. The bar that presses against it won't come back to the right place every time, so it's out of position the next braking event (and it's adjustable and I've tried different settings). Putting a piece of plywood in front of the seat hasn't worked either. I think I'll get a BIG piece. Maybe something that I can lash to the seat somehow. The one I'm trying to use now is 12" X 9" and isn't doing the trick.
I hoped someone else had come up with a fix for this.
