AdventureCoach wrote:
Just curious of why our Onan generators in our boat and RV are designed to operate differently. In the 2006 boat (11KW) it operates at a constant RPM regardless of load but in the 2018 RV (8KW) it runs at various RPMs dependent upon load.
I also like how the transfer switch operates in the RV. There is a slight delay when plugging in to shore power but a 2 minute or so delay when the generator is started. This gives the genset a bit of built in warm up time automatically.
Just curious why the designs are not consistent.
Most Transfer switches, the Transfer maker default is Shore Power with the time delay for Genset. But, most Transfer switches have a DIP switch that changes the priority. I believe the RPM change is on Onans( RV diesels) that have the "inverter" type internal controls. Doug
