koko1usa's avatar
koko1usa
Body side molding
Does anyone know if the Vinyl side strip that covers the siding joint on a 1989 Pace Arrow is still available. It is a stick on type. Thanks, Mike
  • http://www.factoryrvsurplus.com/products.php?product_id=2070
  • if its like my 1990 Champion Lasalle, the side molding is 1 1/2" wide and has a center filler strip that snaps in. Behind the filler strip is where all the screws are that connect it to the body where the upper panels meet the bottom galvanized panels. The automotive type stick on will not do the trick if thats the case. http://www.factoryrvsurplus.com/products.php?product_id=2070
  • Same here. Automotive side body moulding works just fine. Many styles and colors to choose from. Easy to install. Can be a little pricey. Got mine at a surplus outlet in Elkhart at a decent price.
  • You might check with a body shop. Our 1988 Fleetwood Limited needed a new piece of side strip and they were able to find it.
    John
