- SnomasExplorerI bought some lug caps from pacific dully and they had good customer service
- garmpExplorer IIWe've had ours for a while now from summit and have been very satisfied with them. Especially after loosing a front snap on one on two different occasions.
- BruceMcExplorer IIII have a set of Pacific Dualies; the handholes are a bit small, and because they are attached via 4 of the 8 studs, they don't have buffering pads where the outer edge contacts the lips of the rims. As such, they can squeak at slow rotations. I've added a thin layer of foam to the inner lip to stop the squeak.
Otherwise, they look great and add to the overall appearance of the Sunseeker. - IAMICHABODExplorer IIIAfter looking at all options I decided to go with the ones from Pacific Dualies .
I like the direct bolt on to the wheel,not the way the Phoenix uses the replacement lug extensions and spacer.Just seems better to use the original bolts than after market ones. - Dutch_12078Explorer IIIPhoenix makes quality products, just make sure you order the correct ones for your wheels.
- PartyOf_FiveExplorerShops damaged ours over then years, widening the hinges and losing the washers I found to keep salvaging them. I didn't want to pay that much to replace them. So I sprayed the rims grey matte and they look fine on our rig. Much less maintenance.
38,782 PostsLatest Activity: Sep 18, 2026
