Bobbo
Mar 03, 2014Explorer III
lawtonglenn wrote:
I took a dremel tool and opened up the half moon on the wheel simulators to ensure there would be no interference
+1
I had to dremel 3 of the 4 wheel simulators to keep them from touching.
locster wrote:
Please excuse my newbie ignorance, but why do you guys use extended valve stems? With how much they cost including installation, one can buy a portable air compressor and a dually chuck to check and fill air any time. How about when you need to rotate the tires, do you have to dismount the tires to switch the stems also?
We have the extended valve stems so we can reach them with the compressor and dually chuck more easily.
I don't rotate the tires. You won't drive an RV enough to wear the tread, so there is no need to rotate the tires to even out the tread wear. When I replaced my previous tires, at 7 years old, the tread still looked new. The sidewalls were a different story.
38,774 PostsLatest Activity: Apr 26, 2026
