bluebarry1964b
Sep 01, 2013Explorer
daveshan wrote:
Not all hydraulic brakes are found on gassers, some early Alpines also came with Bosch hydraulic brakes and had issues.
This is from a page at Recall record.
2003 Holiday Rambler Neptune brake foundation components recall
Recall Date: Aug. 18, 2004
Recalled Component: Brake foundation components
Manufactured by: Monaco coach corp.
Date of Manufacturing: From Apr. 10, 1998 to Sep. 3, 2002
Units Affected: 8,581
Defect Summary: On certain motor homes, the brake assemblies exhibit elevated temperatures that can lead to catastrophic deterioration of the wheel end components such as bearings, races, spindles, knuckles, seals, hubs, rotors, patch bolts, calipers, brake pads, and abs sensors.
Consequence: This could result in loss of control, and/or the potential for a fire.
How to Fix: Dealers will inspect the front and rear brake calipers for corrosion and replace or rebuild the calipers as necessary. The recall began on August 18, 2004. Owners should contact monaco at 1-800-685-6545.
Recall Notes: Monaco recall no. R02175. Customers can also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
Someone was kind enough on one of my other topics to send me a link to this recall. This is exactly what my brakes did. However, it's been 10 yrs since it was manufactured so I couldn't see how the recall issue could effect my particular coach after so much time. To be safe, though, I contacted Holiday Rambler. They looked into it & said that it appeared that my particular coach was manufactured about 6 weeks after the recall issue was fixed. Close call.
38,776 PostsLatest Activity: May 15, 2026
