Posted By: krivanj on 01/18/16 06:44am
I will mention that on my steps, I only have two, the manual explains about two stops under the stairs that can be adjusted with wrenches to keep the steps steady when down. Mine are Kwikee and this may only be available its two step systems. When I did this, the steps went from wiggly to rock solid.
The Kwikee step manuals can be found online.
Try the above first.....Works for me.
I have three steps.....Four stops. Two on each side on the upper and two on the bottom. Easy fix.
While you're at it check the mounting bolts. If the whole step unit is loose there are lot of things you can do, but try adjusting per the manual first.
