eadeal55's avatar
eadeal55
Bounder Does Not Start
Does anyone have an ignition wiring diagram for a 2004 Ford F53 motorhome chassis?
I can get the Bounder to run if I put the ignition to on and cross the lugs at the starter but it will not start turning the key.
I have verified that AGM chassis battery is good (new) ignition switch (new), park/neutral switch (new), starter and starter solenoid (both pulled, cleaned and re-installed) and ignition fuses are all good.
I'm looking for a loose wire, ground or possibly broken ignition interlock. I've looked around the web for a specific 2004 F53 ignition wiring diagram but no joy. I also asked Fleetwood for tech assistance since I am the original owner, but nothing heard back from them.
I know there are some real technical wizards on this site that can tell me just where to check next.
