tropical36
Jan 30, 2018Explorer II
tealboy wrote:
Do you all have any sense as to quality, dependability, customer service as it relates to these two used coaches? I’m too far away from retirement and really being able to use a higher end and or new coach but realized one option might be to pick up a very clean used diesel coach in the 37-39 foot class for $60-80k. While not a drop in the bucket, not 250-300k either.
On the surface, I like both but wonder what your thoughts are. Have located one of each nearby, both in excellent condition and priced similarly.
Or, is there a different coach in a similar price range that is distinctly better?
After years of researching the best bang for the buck in a DP that would meet our budget and without any real thought of ever buying one, we settled on the Rev in my signature below and once we got the bug for actually pulling the trigger.
You should be able to do the same in an 06, but if an 05, just make sure it's the later LE. If you should go for an 07, just make sure it has an 06 engine. If you look at other brands, then consider a side radiator for comparing apples to apples. Then check the leather inside for comparing oranges to oranges.
