Britches's avatar
Britches
Brake Caliper Kit
My 1988 Ford E-350 motor home the left front brake started leaking brake fluid. Appears to be the caliper seal I know nothing about brakes, so I am wondering if a Caliper Kit would repair this problem. Any person with experience in brakes your thoughts would be helpful.
  • Why would you chance the rebuild?
    Easier to replace the calipers for about $65.00 each
    what is your time worth.
    The rebuild kit SHOULD take care of the leak unless the piston is scored BUT a rebuilt WILL fix the problem
