flphil
Jun 20, 2014Explorer
Brake Calipers
93 Gas Winnebago Vectra 34 ft. P30 chassis. Does anyone know if I can just buy brake components for Chevy Van P30? I am going to replace pads, calipers, and rotors. Thanks, flphil
enblethen wrote:
Make sure you lube the key-way with brake lube.
Clean the groove good before starting.
The brake pads may need to have the "ears bent in slightly to hold onto the caliper frame work or you will hear clicking when the brakes are released.
Use High temperature brake fluid.
