Home_Skillet
Jun 05, 2020Explorer II
time2roll wrote:
Consider a motive products pressure bleeder.
Probably need the 2 or 3 tab ford adapter.
https://www.motiveproducts.com/collections/domestic-bleeder-kits
Get 2 or 3 quarts of Dot 4 and start with the longest run until it runs clear. I recommend Valvoline or Ford fluid.
Absolutely, 100% use this flusher.
I have one and did mine by myself.
The Ford fluid is the best, has a very high wet boiling point.
Also, would be a good time to replace the front rubber brake hoses. They tend to delaminate internally, causing the brake calipers to "stick".
38,782 PostsLatest Activity: Sep 19, 2026
