pappaone
Jun 05, 2014Explorer
Brake Fluid
I noticed the brake fluid was a little low on MH and was going to add some when I notice what I have says DOT3 HIGH Temperature SYNTHETIC.    Not knowing what the present fluid is will it make any dif...
rgatijnet1 wrote:I agree with Ronnie, at least flush your system and put new fluid in!pappaone wrote:
Not knowing what the present fluid is will it make any difference if I add the SYNTHETIC to what is there?
Thank you
Brake fluid is not something that gets low unless you have a leak, or your pads/shoes are worn way down. I would suggest that you have a complete brake inspection and have them flush the old fluid out of your entire system and replace with new fluid.
On my coach, a complete fluid flush uses 3 quarts of fluid.
