pappaoneExplorerJun 05, 2014Brake FluidI noticed the brake fluid was a little low on MH and was going to add some when I notice what I have says DOT3 HIGH Temperature SYNTHETIC. Not knowing what the present fluid is will it make any dif...Show More
wolfe10ExplorerJun 06, 2014Bottom line:New brake fluid boils about 500 degrees F.Hydrated brake fluid (i.e. older fluid) boils at 284 degrees F.Any questions????
Related ContentBrake fluid change?Brake fluid flushbrake fluid?Wiper Fluid in Water linesBrake fluid flush
