StarrsExplorerMay 18, 2013brake fluid?where is the master cyl at? I need to put brake fluid in and I dont know where? 1989 fleetwood southwind----sorry ---chevy
PauljdavExplorerMay 30, 2013chances are you have very worn brakes or a leak somewhere in the system. When my class C did that the back brakes were toast and the master cylinder was leaking. Nothing 800 bucks does not cure. I also needed the drums replaced. They were cracked. Paul
Related ContentBrake fluid change?Brake fluid flushBrake FluidWiper Fluid in Water linesBrake fluid flush
