58roadhog
Jun 25, 2013Explorer
Brake for toad
My Brake Buddy has died and I am looking for a good replacement. Any advice on a good system would be appreciated. I have a 2009 Allegro Bus and am towing a 2011 Chevy Silverado.
ThunderingQuiet wrote:luvlabs wrote:
An SMI Airforce 1 would be the way I would go. You have air brakes on the bus and the AF-1 ties directly into that. Nothing to remove each time, just plug in your electrical and an airline.
X2 on that.
I've been using the AF-1 for about 3 years. It works great, dependable and no problems. The best thing about this is there IS NOTHING to adjust. Just hook up the quick disconnect air line and the cable going to the breakaway switch.
There is nothing to do inside the car, no big box that sits on the floor, just unlock the steering wheel and pull a fuse if your vehicle requires it. But then again if you do it with the system you have now that's a mute point. When you're done towing no box to remove and have to store somewhere.
SMI Air Force One
