dramsey1's avatar
dramsey1
Brake In A Box Questions
I am considering a Blue Ox Patriot braking system for my toad and have a couple of questions. The toad is a 2016 Ford Focus and the negative battery terminal must be disconnected when towing. I am thinking of running a charge line into the car to plug the patriot into. Will this work? Does anyone use a patriot or similar system that does not connect to the vehicle battery? Will the break away switch still operate? Perhaps the breakaway switch will work off the internal Patriot battery one time? Appreciate any info you can provide.
