Seabass69ExplorerMar 15, 2023Brake Issue2004 HR scepter, the front brakes like to lock up hard if you have to use ter brakes very hard. dry ground or wet they will lock and slide quickly.... any ideas on what to look at first? Maybe just ...Show More
wolfe10ExplorerMar 16, 2023And, if floating caliper disk brakes, check that the pins (that the caliper floats on) are clean and lubed.Pretty easy for dirt, rust, etc to not allow the "lazy pad" to pull away from the disk.Since it is "air brakes for sure", no worries about changing brake fluid.
Related ContentTowing lights issueBrake Issuetrailer brake issueElectric brakes issue12 Volt Power Issue
