trashguy's avatar
trashguy
Explorer II
Apr 10, 2018
Brake Job on 95 F53 ***Update***
I have some calipers that seem to hang up, and after getting outrageous quotes on the job I figure I can tackle it myself. Ive done brakes on other vehicles so it shouldn't be too much different. Any threads on tips to the job? I want to do it once and do it right.
Update
*** Well my parts didn't come in and it was a beautiful spring day in Northern California and my usually more grounded better half and I decided to visit the local RV dealership and well this led to that and let's just say I won't be doing brakes after all.***
  • I fought brakes on my 97 constantly. As stated, lube pins and replace hoses.
    It the main thing I learned that made the biggest difference was to learn to drive like I didn’t have brakes.
    Leave a big gap in stop and go traffic so you didn’t use the brakes. Drop it into 2nd and let the engine slow you down. Go down steep grades in 2nd. Etc.
  • On a F53 460 there is no such thing as do it once on a brake job. You'll find out they need constant maintenance.
    More then likely you already have new calipers on the rig that old, and the slide pins need to be cleaned and lubed. I'm sure the thing about the hoses is very possible, I see it quoted on the forum all the time. I just never ran into anyone in life on the road that had that problem.
    What you'll learn is if the calipers are good, then the pins are sticking. They need to be cleaned and lubed every other year or more.
    The brake fluid is also an issue and should be changed every other year or more. It's just the nature of that beast.
  • If you change the two front rubber hoses, be sure to replace the one rear rubber brake line as well. Just because your calipers are sticking does not mean they need to be changed. Just clean up the slide surfaces and apply brake lubricant, which can handle the high temps.
  • At 20+ years old and sticking calipers... consider new/rebuilt calipers and new hoses all around.
  • A common problem is to have the brake hoses going from frame to caliper fail internally and then act like a check valve and not release pressure causing dragging.
    Also the calipers float on the brackets and get corroded and drag.
    It's not that hard to change, find a utube video and go to it.
