tcbkenpo's avatar
tcbkenpo
Brake light fuse
Hello,
I have a 2009 Sport Coach elite with a freight liner chassis, my running lights and brake light stopped working. On my dash it is saying check brake fuse. I can not find where brake fuse is located. Once RV is running I have no dash warning until I put on the brakes. If anyone has the same RV or knows where I may find the brake fuse I would really appreciated it.
Thanks Dave
1 Reply
  • You need to find the "freight liner" AFT fuse box. May be in the bay with the power cord. Mine was under a hard to remove cover.(I installed a removable panel after finding it) It looks like the FWD fuse box, but the cover is screwed on. Inside are fuses and relays. There are several flat plugs going to it. Also has the fuse for the tow plug.
    The coach builders like to hide this fuse box. Has been problem for a lot of people.
